Adding Speed Control to Cassette Player
the_lurking_ear
Post by the_lurking_ear » Sat Jun 08, 2013 11:25 pm
I'm interested in hacking a cassette player so I can vary the playback speed with a pot. Ideally it would let me go in reverse too. Does anybody have experience with hacking/bending cassette players and how I might do this?
Discipline Jar
"How do I get that chhhhrkrkrkrk sound?" -Sleep of Ages
Post by MKULTRA » Sun Jun 09, 2013 4:10 am
the_lurking_ear
Post by the_lurking_ear » Sun Jun 09, 2013 7:11 pm
MKULTRA wrote:An LM317 works fine as a regulator.
Cool, Thanks.
Discipline Jar
NoizeHack
Post by NoizeHack » Sun Jun 09, 2013 9:29 pm
So you are running the tape deck on lower voltage so the motor runs slower?
This might be more complicated, but if you wanted the rest of the tape deck to run on regular voltage you could use a 555 or arduino or something to adjust the PWM to the motor that spins the tape, adjusting its spinning speed? I don't know, I'm just guessing here.
Post by crochambeau » Mon Jun 10, 2013 1:42 pm
The VR is on the motor leg, not the entire circuit.
Though honestly, I like the way starved walkmans have sounded in the past. If I had to choose between speed and gnarly distortion, I'd probably go with the latter.
Post by MKULTRA » Tue Jun 11, 2013 12:45 pm
Al.Machine.O
Post by Al.Machine.O » Tue Jun 11, 2013 1:07 pm
Best fred in this forum in 2013.
1000 thanx, guys!
:salute:
Laura91 wrote:To all that use feedback loops:
Flooping causes hiccups.
Achtane
Post by Achtane » Sat Jun 15, 2013 8:16 pm
What I did with mine was find the trimpot that acts as a fine speed control and wire a 50k pot to it...now it can go so fast that it feels like the motor's being damaged. Recording while it's going way fast is cool 'cause the playback is super low-pitched when you set the speed to normal.
Some decks' guts are laid out better than others so this method's difficulty can range from tedious and annoying to total nightmare.
angelhair0
Post by angelhair0 » Tue Aug 06, 2013 9:38 am
i havent looked into it...but would your average deck vs a walkman only running at 3v would make the voltage of the pot needed for this bend vary? or are these motors pretty much the same on all cassette decks? i need to place an order for pots...im totally out, so knowing this would definitely in help in what i throw into my order. i have at least 4 or 5 walkmans with no speed control laying around that i'd love to do this to.
Post by xdugef » Tue Aug 06, 2013 9:43 am
angelhair0 wrote:or are these motors pretty much the same on all cassette decks?
No I'd expect larger console decks to use stronger motors that required upwards of 12volts.
If you are going to order pots it wouldn't hurt to get a wide range of them for experimentation.
Or you can always put several pots in series to increase resistance.
Post by crochambeau » Tue Aug 06, 2013 9:47 am
No, motors vary. I'd research the parts in AC powered decks, for example if it's a DC servo you would probably be better off in modifying the control circuitry. That said, pretty much all of my servo drives already have pitch control...
Also, while it predates compact cassette, I have an open reel machine that runs an 117 volt AC motor.
Moral of the story is: don't assume anything.
But buy the parts anyway, they'll get used sooner or later.
angelhair0
Post by angelhair0 » Tue Aug 06, 2013 8:06 pm
i will probably be sticking to mostly dc decks...walkmans and such. but who knows. i might break open one of these big decks at some point.
ive been saving tapes for reels...happened upon bags and bags of mystery reels right before i moved to chicago an couldnt resist cramming them in the car because im waiting for that perfect RTR machine to fall into my lap. jason crumer's set at sux by suxwest sold me.
Post by xdugef » Mon Feb 20, 2017 7:37 am
aelycarter
Re: Adding Speed Control to Cassette Player
Post by aelycarter » Thu Sep 14, 2017 4:15 pm
I'm trying to use voltage to control speed/pitch on my Sony TC-D5 ProII. I don't trust myself with making any internal mods. Does anyone know of an external variable voltage control that I can just plug into? Ideally without the need of banana plugs/adapters?
Post by Misomusist » Thu Sep 14, 2017 6:30 pm
An external voltage may let you slow things down, but it's unlikely you can speed things up as the circuit will be regulated :mrgreen:
