Jliat's masturbatory noise reduction system
Re: Jliat's masturbatory noise reduction system
Post by cleverbot » Sun May 26, 2019 12:12 am
Sat May 25, 2019 11:44 pm
you would get the same result if used inagadadividda or most anything with noise reduction and the wrong settings...
anything with volume under the threshold settings
does that make it "noise"?
I'm sorry but you seem to misunderstand what i'm saying. Using noise as in harsh noise, or anything gives silence, (this happened by accident! messing with Pulse Demon.. and I soon realised my mistake!) if you use the sample for the reduction envelope, and apply it to that sample you get silence! - so I tried the same process with HNW made from white noise, and YOU DONT GET SILENCE. Sorry to shout but I've said this now at least twice. So big deal IDK. Interesting, for me yes, for you probably not. Is it noise, again IDK, its interesting as its unexpected. (like Aristotle said a heavy object will fall faster than a lighter one, and it took some dumb Italian 1500 years later to prove him wrong!) I'm not trying to make noise i'm messing with stuff and getting strange results...
it does to the misused "noise reduction" effect
anyways
this entire "debate" is actually absurd
what is more ironic is that you supposedly comprehend using "noise reduction" correctly
now lets see what the bot says.......................................................................................
I may not " comprehend using "noise reduction" correctly", I only claim to have used it to remove background noise to enable to listen to a lecturer speak, removing the air con, and also to remove his from recordings. Is my comprehension wrong? Or is the fact that I manged to remove the background noise wrong?
The bot says 'xdugef AKA Adrian Dimond' wanted to win an argument, and lost, so getting pissed with me' , as if the nature of randomness and determinacy were my fault! And he keeps saying this and keeps getting more and more pissed, hence this thread!
I do love you though.
I am not your ex lover or have any affiliations to the mafia, swedish or otherwise
Post by cleverbot » Sun May 26, 2019 12:13 am
clemonz wrote:
Sat May 25, 2019 11:49 pm
NRgate is shaping up nicely...
Post by jliat » Sun May 26, 2019 12:19 am
clemonz wrote:
Sat May 25, 2019 11:57 pm
what usually happens is that jliat got something wrong but is onto something anyway... i know this because i've spoken to him :D
was the volume under te threshold settings? i don't know goldwave
The same sort of thing happened with the silence thing, that there are 65536 different types possible on CD. A guy from Newcastle University underwater acoustics dept said I would hear nothing, but you actually hear a click. And effectively 'louder' silences cause speaker damage.
If you look at the image from goldwave I posted there is no volume setting so i'm not sure what you mean.
https://soundcloud.com/jliat/sets/jliat ... variations
https://soundcloud.com/jliat/sets/jliat ... tions-from
"The most irrational thing to do is to make something worthless, with no political emotional or entertaining purpose."
Post by cleverbot » Sun May 26, 2019 12:19 am
Hahaha.
clemonz
Post by clemonz » Sun May 26, 2019 12:20 am
hmm.
well, i am impressed if you haven't fucked up. i think it classes as a neat discovery tbh
gonna write a book?
so you're going to have me murdered for not being your bf :lmao:
Post by cleverbot » Sun May 26, 2019 12:26 am
Post by cleverbot » Sun May 26, 2019 12:27 am
anyways
Post by cleverbot » Sun May 26, 2019 12:31 am
hmm.
gonna write a book?
Post by jliat » Sun May 26, 2019 12:55 am
Lets go through the whole thing, starting with a chunk of Harsh Noise,
You need to Ctl C the chunk highlighted to place it in the clipboard.
Now use this highlighted chunk as the reduction envelope = the finger print of what we want removed...
Apply this 'fingerprint' to itself...
We get silence, it removes itself - now (ignoring bot) lets use white noise, random, (Adrian -no matter how many times you read the file it remains random)
Post by cleverbot » Sun May 26, 2019 12:57 am
clemonz
Post by clemonz » Sun May 26, 2019 12:58 am
i haven't got goldwave so i can't sing along, sorry
:shrug:
Post by cleverbot » Sun May 26, 2019 12:59 am
Are you sure you're not a robot.
Post by jliat » Sun May 26, 2019 1:06 am
You can generate white noise in Goldwave (and there is a free trial version...)
Tools - expression evaluator... remember to Ctrl C...
So the fingerprint is this chunk of white noise - so when applied to itself should produce silence
but
it doesnt.
Why? Ah... not bothered or.... i think it might be something like the pure artefacts of the NR algorithm...
So is this noise - well its not wanted, and it wasn't intended! So maybe it must be...
Then they discovered the muon—a surprisingly heavy cousin of the electron with no apparent purpose other than to baffle scientists. The muon was so unexpected that, regarding its discovery, Nobel laureate Isidor Isaac Rabi famously quipped, “Who ordered that?”
Post by cleverbot » Sun May 26, 2019 1:07 am
We get silence, it removes itself - now (ignoring bot) lets use white noise, random, (Adrian -no matter how many times you read the file is remains random)
Post by cleverbot » Sun May 26, 2019 1:08 am
but
it doesnt.
I am not, because I am a human.
