Ringing In My Ears
DonaldKrump
Ringing In My Ears
Post by DonaldKrump » Fri May 11, 2018 8:55 pm
A compilation from the Network focused on ring modulation.
Ringing In My Ears
by Network Of Individualized Sonic Extremism
https://voidofnoise.bandcamp.com/album/ ... in-my-ears
Re: Ringing In My Ears
Post by WhiteWarlock » Fri May 11, 2018 9:40 pm
Louis Barron's original "Ring Modulator" schematic^
The Musicians Union refused to let the Forbidden Planet soundtrack be labelled in any way as "music", so despite the critical acclaim of the work, as "creators of electronic tonalities" and not "musicians" Louis and Bebe were ineligible for Oscar nomination. The Barrons treated each ring-modded circuit that they built for the film as an "actor" rather than an instrument, with its own characteristic voice and behaviour patterns. As getting the required sounds out of these "monsters from the id" required burning out the circuits, they learned to record everything they did, eventually editing down hundreds of hours of improvisation into tape loops – another technique possibly first pioneered by the duo.
What are they? Ring modulators are neat little gizmos that make things sound wobbly and metallic and cool. If you're in any way familiar with the phrase "EXTERMINATE! EXTERMINATE!" then you've heard a ring modulator.
http://homepage.powerup.com.au/~spratle ... rimer.html
Post by melkobukva » Sat May 12, 2018 4:24 am
Fun Guys from Yuggoth and Discordant Discharge both did a great job. Will keep an eye on them from now on.
Ring mods are awesome tools, especially if you get to choose both signals. I have two of those and five usual ones with a built in oscillator.
Damn, should have submitted to this comp using all of them at once :(
DonaldKrump
Post by DonaldKrump » Sat May 12, 2018 12:53 pm
Maybe someone who has a label here would do another comp...
And thanks WhiteWarlock, no idea it had such a great history. Gonna get a nice analogue pedal eventually...
Post by WhiteWarlock » Sat May 12, 2018 1:50 pm
you can make Ring Modulator pedal on stripboard for couple dollars
yet suggest active 9v versus simple 2 audio transformer passive
not very complicated
Post by WhiteWarlock » Sat May 12, 2018 2:27 pm
Arp RingMod circuit using readily available CD4011 IC
slap some pots & opamps on inputs & output
personally like the sound of that basic Arp ringmod
or you can go with the DOD Gonkulator
Post by WhiteWarlock » Sun May 13, 2018 8:06 pm
CD4011 Ring Modulator
ARP Solus CD4011 Ring Modulator
MS20 CD4011 Ring Modulator
Redrawn MS RM
Post by WhiteWarlock » Wed May 16, 2018 7:51 am
So you want to sound like a Dalek eh?
Short of going for a quick trip to the planet Skaro there are a few things you need to keep in mind.
The problems with modelling analog effects based on output only
One of the challenges that anyone who tries to model an effect based on hardware or analog processes is that the digital world of audio processing tends to be too perfect. Another problem is that specific algorithms and techniques are not easily transposed into modern day desktop music/audio production environments (or have little in the way of digital equivalents) or aren't made readily available. Sometimes the artistic edge of sounds created using imperfect or inferior technologies or mediums is a necessity. From my own personal experience there is a huge divide in the area of electronic effects such as the emulation of analog oscillators and filtersections, which often sound so much more alive, far brighter and fuller in sound than a lot of attempts to replicate them using entirely software based digital signal processing algorithms.
The Daleks
When the Daleks first appeared in 1963 a lot of the technology that modern audio production facilities take for granted just weren't available to production teams. The main piece of technology involved in the creation Dalek voices was what is known as a ring modulator. A ring modulator works on the premise of taking two audio sources that are involved in a process which takes the sum and differences of the frequencies that are a part of the two audio sources (and in the case of software a multiplication of signal content/frequencies occurs). Typically a ring modulator may provide different types of wave to modulate any input by (i.e. by a sine wave). Thus the two sound sources are defined as the input (vocal) and the waveform that is being used to modulate it.
In the case of a ring modulator we typically talk about modulating by the amplitude of waveforms (The amplitude being the 'height' part of the wave). In the case of the Daleks the original setting was a modulation frequency of 30hz. In the case of the Daleks created by BigFinish we are looking at a modulation rate around double (November 02/2004, the guess of double the modulation rate has been proven right by information published at justyce.org from an interview with Alistair Lock, this does not mean all BF stories follow the pattern). However there is a lot more to the sound unfortunately, and from another point of view I suspect that if you looked at the output of the original ring modulator that the modulating waveform i.e. a sine wave may in fact may NOT be perfect. Recreating such malformed waveforms is probably near impossible as most digital equipment and algorithms attempt to be extremely close to perfect (or attempt to makeup for their inaccuracies). In the world of analog hardware not every sine wave is perfect and there are unique flaws and design limitations to most pieces of equipment that affect the output (of the equipment) as well.
The Degeneration of the Daleks
From listening to various recordings of Daleks it's not hard to see that the effect employed has become far more complex and different over time. On one end of the scale we have the first appearance of The Daleks in 1963, then the final appearance of the Daleks on television (yes I'm sticking with that fact) in "Remembrance of the Daleks" 1988. There is a stark contrast between Dalek vocals produced in 1963 to those produced in 1988. Over the years it appears that the settings employed to create them has changed; at a guess this fact is primarily because the ring modulator used was most likely utilized in many different programs (not just for vocal fx I'd imagine). The other fact that made replication of the sound is that it appears that nobody really bothered to write down how they did what and why; leading to all kinds of issues and the appearance of quite aweful fx as heard on BBC trailers around the time of the release of "The Mind of Evil" on VHS (1998). From my own little investigations the following facts in regards to the sound probably stand as being true/or at least perceptively so:
Daleks in 1963 were done very simply with little/next to no pre or post production processing beyond the actual ring modulator
Daleks in "Genesis of the Daleks" & "Resurrection of the Daleks" & "Revelation of the Daleks" have been extensively post produced.
Daleks in "Remembrance of the Daleks" have more in common with current off the shelf digital fx processing technology than any other generation of Daleks since 1963. These Daleks were extensively pre & post produced. There is no pitch shifting involved in creating this generation of Dalek either, although they do seem to be rich in higher frequencies than prior generations (I tend to call them "Happy" Daleks, as they are spectrally speaking rather bright). I suspect this generation was based on the effect as heard in such episodes as the William Hartnell era story "The Chase" (1965), which would probably have been made available to the production team at the time. Further these Daleks do not sound to me as if they were made with the original ring modulator or if they are there was some kind of routing and further processing involved, although I quite doubt it. I suspect this effect was generated through a similar process to the Cybermen that appear in the 1988 adventure "The Silver Nemesis".
Just a brief comment. The ringmodulator setting for this lot would seem to be ~24hz. (Which just happens to be a similar setup as used by JM&KH in their "Millenium of the Daleks" adventure).
Ressurection of the Daleks: A slightly closer look
After having a listen to the dialogue on my old beat up copy of this serial it would seem some of my guesses about the effect used here may well be true. The effect in Ressurection has departed quite significantly from the original means of making the Dalek effect as it had been produced in prior stories. It would appear that the production team had difficulties trying to reproduce the irregularities of the original analog signal chain and modulation source(s). Something extra had to be done and it appears some form of digital distortion was used (perhaps in attempt to emulate the older effect, then giving up on trying to achieve it and finding something pretty nice, or a happy accident that allowed them to maybe 'modernize' the effect?) in conjunction with a ring modulator (the original? Maybe not).
Remembrance of the Daleks: A more detailed look
Since coming into possesion of a retail copy of the original videotape of this adventure (it's a good thing this isn't a review of the story but rather the fx I think!) a number of things have become obvious. It seems a somewhat different approach was taken in Remembrance to many other Dalek stories in that the Dalek vocal fx seems to be all over the place in terms of settings and modulation. There is very little consistency throughout the story in terms to the Dalek vocals and how they were processed. This might make it sound as if things were haphazardly thrown together, but in fact I believe the reason this was done to emphasize the emotion and state of distress/operation of the various Daleks even within the same "faction" (it may also be that the people putting the program together got a tad lost at times considering there is very little obvious difference between the factions bar the colour variations). From my own observations at a guess this has led to Dalek vocals with a huge difference in the modulation frequencies used, with an educated guess that it switches between anywhere around ~10-30hz. So there goes the myth of all Daleks being at 30hz with different pitch variations in the performances of actors only doesn't it? Gee this article is starting to sound very fan boy sad (are sound designers ever seen to be as sad?).
There will be some sample files up with some contrast as soon as the author of this article can get around to it/feels well enough to.
A short reminder for people who have made or intend to create Dalek like voice fx
The Dalek Vocal effect is NOT achieved by flangering, phasing and or pure pitch shifting. Those approaches tend to sound horrid and incredibly amateurish. The 'silver buillet' solution: use a ring modulator. 30hz. Tweak. Not to mention try and sound like a Dalek.
Another terrible myth is that the signal modulation setting on the ringmodulator should be set in excess of 100hz or multiples of 20-30hz, this is not the case. Vocals become VERY difficult to discern at high multiples in that range.
Post by ¼ dead » Thu May 17, 2018 4:16 am
I like how the cover looks like a Louis Wain cat made out of ears. :kitty:
DonaldKrump
Post by DonaldKrump » Thu May 17, 2018 11:31 am
Ha! I totally see that now.
Post by melkobukva » Thu May 17, 2018 11:41 am
I thought it was a rat.
