GRANULAR SYNTHESIS COMPILATION - TRACKS NEEDED
Post by killing raven sun » Fri Nov 02, 2018 4:48 am
TRACKS NEEDED, MUST CONTAIN GRANULAR SYNTHESIS
more info:
viewtopic.php?f=1&t=20106
HADRON – VST and AU
OPEN SOURCE
The Hadron plugin is your ultimate granular synthesis tool. In fact it is such a complete implementation of granular synthesis we’ve renamed the technique to particle synthesis. The plugin is of course free and open source.
For your convenience, we’ve made a preset system allowing you to quickly get started making music with it. All presets have selected “expression controls” to allow creativity and flexibility, and you can morph between presets for ultimate creativity. The plugin comes with a basic set of presets, and you can buy additional preset packs to expand your sonic palette. This kind of presets is called “states” in Hadron.
Hadron can be used as a synthesizer or an audio effect. It can also seamlessly morph between different sound processing methods, so you can make the plugin gradually change from synthesizer to audio processing mode. This is all part of the state morphing system, accessible via the big 2D joystick control.
You can also use live sampling as a sound source for manipulation with Hadron, as well as audio files and live audio input.
http://www.partikkelaudio.com/
