Your Setups
MountKuma
Re:
Post by MountKuma » Mon Mar 20, 2017 4:10 am
JayVolunteer wrote:
Fri May 13, 2016 10:05 am
Cheers Crochambeau, I've plugged everything in a zillion different ways since my last post, added a couple of pedals, taken away the synths. Having fun with it, nice one!
Just joined the forum myself and was also looking at a set up with the Volcas, can I ask why you removed them from your set up?
buttercup_insurgent
Re:
Post by buttercup_insurgent » Wed Apr 05, 2017 12:30 am
Soulsick666 wrote:
Mon Feb 06, 2006 11:19 pm
I'm asking because I have a marshall amp which don't won't to blow up by sticking something in there that shoud be there
what exactly is the difference between a contact mic and a regular one?
pretty much none of it will be stuff that's "meant" to be there, just play away :) Marshall's are usually solid enough to take it. I'm using a Peavy Max115 bass amp with no problems if that helps though.
Re: Your Setups
Post by Misomusist » Wed Apr 05, 2017 3:49 am
If it's a Marshall with tubes, they can be sensitive to having speakers attached properly, but the input side doesn't really care what's connected.
Re: Your Setups
Post by ¼ dead » Mon Apr 24, 2017 3:46 am
Cross-post from the vantablack board:
Re: Your Setups
Post by FireAlarmPoet » Sun Jun 25, 2017 3:07 pm
Work in progress. Better gear porn to follow.
Re: Your Setups
Post by FireAlarmPoet » Sun Jun 25, 2017 5:15 pm
Okay, maybe not better...
Re: Your Setups
Post by FireAlarmPoet » Sun Jun 25, 2017 5:19 pm
Re: Your Setups
Post by FireAlarmPoet » Sun Jun 25, 2017 5:20 pm
I suppose a lot of these are more suited for the "devices" topic. Also having trouble uploading more than three attachments per post.
Re: Your Setups
Post by Misomusist » Mon Jun 26, 2017 5:24 am
I think a lot of forums cap at three attachments, never tried on this one.
Re: Your Setups
Post by ¼ dead » Mon Jun 26, 2017 10:58 pm
This reminds me of one of those busy boards for kids. I loved vegging out with those as a kid. Cool idea.
Re: Your Setups
Post by Sleep Of Ages » Wed Jun 28, 2017 8:59 am
i know it's gear porn but you don't need to be fapping in the exact moment you take the picture.
Re: Your Setups
Post by Sleep Of Ages » Wed Jun 28, 2017 9:00 am
Even if you are Fap.
Re: Your Setups
Post by Fletcher » Sat Jul 01, 2017 3:09 pm
Setup used today
This is what I made sounds with today. Quite a clean setup.
HeliacalShimmer
Re: Your Setups
Post by HeliacalShimmer » Tue Oct 03, 2017 10:38 am
Dyecap
Re: Your Setups
Post by Dyecap » Sun Oct 08, 2017 12:35 am
Recently enjoyed floop for the Access and Influence tapes and forthcoming CD compilation of...
