Casssettte Player Mods
Post by Sleep Of Ages » Mon Dec 03, 2018 2:48 pm
....anyone?
Re: Casssettte Player Mods
Post by WhiteWarlock » Mon Dec 03, 2018 2:59 pm
my library of congress tape deck for the blind doesn't need mods
yet it does occasionally need new rubber band
as replacement belt(just replaced the belt 3 days ago)
Post by WhiteWarlock » Mon Dec 03, 2018 3:03 pm
add pot for resistance/speed on play motor voltage & switch for changing polarity(direction)
Post by WhiteWarlock » Mon Dec 03, 2018 3:26 pm
REDACTED
just grabbed old tape and pressed record few minutes ago using library of congress tape player for the blind
speed/direction changes does super slow & super fast...
the entire range via slider & switches... that track is super slow mode with flipping between forward/reverse playing the slider
Post by timdrage » Tue Dec 04, 2018 4:10 am
You can get cheap tiny PWM motor speed controller boards on eBay and other places,they have screw terminals so you don't even need to solder, just cut the wires to the motor and splice the controller in between, then you can make any tape deck slow to a warped crawl
Post by crochambeau » Tue Dec 04, 2018 10:37 am
Does it record? If so:
Plant a switch in line with the erase head so you can do sound on sound.
diurnalburdens
Post by diurnalburdens » Wed Dec 05, 2018 12:41 am
Have you tried this with a four track? Pondering doing this with mine, though I need to see if there's enough space inside the case for it.
Post by timdrage » Wed Dec 05, 2018 1:58 am
I haven't as my only current 4-track is too good to risk messing up. :) also it already has 2 speeds and a decent range of pitch control, and i suspect some modification of the existing pitch control circuit would be a better tactic
would be good to try on a cheapo one for sure tho!
joshenjammer
Post by joshenjammer » Thu Jan 03, 2019 8:03 am
I've got that same one, my roommate found it at a thrift store for like a dollar. I didn't realize it was a hot commodity until I saw it in this video and almost shit myself
https://youtu.be/tVMo4F2H0dY?t=1089
more like noisy ambient but fuck it
https://ihlyatt.bandcamp.com/
