Post by MKULTRA » Thu Mar 29, 2018 3:55 am
Re: Reliable Soldered Connections
Post by xdugef » Thu Mar 29, 2018 9:12 am
You to tell me twisting the wires and holding it in place with hot glue is not sufficient??
Post by fire » Thu Mar 29, 2018 3:43 pm
rich people and their fancy solder and hot glue :roll:
TWISTED 4 LYFE
Post by jliat » Sun Apr 01, 2018 8:35 am
So guys where am I going wrong?
Post by crochambeau » Sun Apr 01, 2018 6:10 pm
We'd have to see your technique to answer that question. I wouldn't want to use that for SMD (or at all, if I'm being honest) but people have done great things with worse.
Post by MKULTRA » Tue Apr 03, 2018 9:57 am
Post by xdugef » Tue Apr 03, 2018 10:49 am
We had a soldering project in shop class.. we had to make these coin tray with a handle and each corner connection had a different type of solder, braise, spot weld or rivet.. I forget all the methods used.. I think there were two others.. I still have the thing. Anyway I did all the joints correctly but had made the tray a half inch narrower than specified and one of my redneck classmates tried to rat me out to the teacher after he approved by welds and shit and his response to them was "well at least he made the joints correctly". :lol:
Post by fire » Tue Apr 03, 2018 11:06 am
" You keep making mistakes because you are focusing on the solder joint and not what you are doing."
perfection requires no attention to detail for at that moment of focus you err
Users browsing this forum: Google [Bot] and 5 guests
