Small and cheap with good low freq mic
DonaldKrump
Post by DonaldKrump » Fri Mar 09, 2018 7:52 am
I have some random cheap mics but they barely pickup anything low. Any good cheap ones, like the small lapel sized mic but pickups more than vocal range?
like closest thing to this that has range: https://www.ebay.com/itm/Small-Clip-On- ... SwogpaaBXz ??
Re: Small and cheap with good low freq mic
Post by Misomusist » Fri Mar 09, 2018 12:58 pm
So that's a mic, less than $3 which has a 20Hz - 20KHz range.
Are you looking for cheaper than this, or better than this?
DonaldKrump
Post by DonaldKrump » Fri Mar 09, 2018 1:28 pm
I'm sorry, yes, it can be wayyyy more than a couple bucks. Like a small, quality mic, worth the money. I'm basically gonna try not to be as cheap b/c that strategy hasn't paid off.
Post by xdugef » Fri Mar 09, 2018 2:40 pm
Whaddya want like ultrasonic.. gonna record some bats or maybe whales?
DonaldKrump
Post by DonaldKrump » Fri Mar 09, 2018 2:53 pm
Hey, making a whale album would be a good way to supplement my hobbies.... but no, just want more lower end in my recordings, especially when things are already getting amped/overdriven/distortion and that leaves them so mids and high mids. Something that would capture lows too.
Post by crochambeau » Fri Mar 09, 2018 9:13 pm
A lot of low end hinges squarely on microphone technique. Proximity effect, acoustics, etc.
If you're still at a loss, maybe try wiring up an old speaker as a microphone. Then veer into EQ, preamps, etc.
DonaldKrump
Post by DonaldKrump » Sat Mar 10, 2018 8:23 am
alright, good to know.
