sound collage with tapes
mylenology
Post by mylenology » Sat Mar 03, 2018 8:53 pm
I'm trying to find a nice method to make tapes collage. Basically, i want to emulate the classic manual method of film editing. Cutting tapes in parts, and then put them all together in a different order.
I tried with cassette tapes, scissors and scotch tape, but it was a complete hell.
Re: sound collage with tapes
Post by MKULTRA » Sun Mar 04, 2018 1:18 am
Post by jliat » Sun Mar 04, 2018 1:40 am
You will find on YouTube videos of this and ebay where you can get the right stuff. :roll:
Post by crochambeau » Sun Mar 04, 2018 2:09 pm
You want to degauss any metal used for the cut for pop free splices as well.
Post by FireAlarmPoet » Sun Mar 04, 2018 5:28 pm
:!: Never even considered that, thanks!
Post by xdugef » Sun Mar 04, 2018 8:39 pm
cut and paste on a computer works a treat!
Post by MKULTRA » Mon Mar 05, 2018 12:36 am
Post by jliat » Mon Mar 05, 2018 12:58 am
Its a trend though elsewhere to revert back to previous technology, such as wet photography. And in art galleries use of old Sony monitors and video tape, through to OHPs and cine. And in music reel to reel decks and analogue... and of course the growth in vinyl. I'm not sure what is behind this retro enthusiasm?
Perhaps something deep in the idea of a better future being an impossibility :?: or not particularly nice? I have a couple of Braun super 8 cameras, and several Polaroid Land Cameras from the 60s... :D
Post by crochambeau » Mon Mar 05, 2018 7:30 am
My own dystopian fantasies aside, I think the root cause is tactile understanding. You can hold a relic piece of equipment and know that if push came to shove, a human with finger tools can still work or repair the innards and handle the media. A catastrophic failure does not remove the material, it simply delays the use and application of the material.
Latched digital words stored by the millions on a cryptic substrate are hardly as reassuring.
Post by jliat » Mon Mar 05, 2018 8:27 am
Sure, one could once take things apart and figure out how they worked, maybe, and then try to put the thing back together! My first cars were 2CVs - which you could fix yourself but i always had bits left over on putting them back together... :roll:
Post by fire » Mon Mar 05, 2018 8:32 am
i have used a "dj" style mixing setup
i have 8-12 tapes going into various mixing devices, blending the sounds on the fly and switching tapes out as needed, i record on reel to reel but you could cheat and use computer or just cassette
one way i organize is to color code and number cassettes for their position in the mix
this produces a more layered effect with some crossovers blending out the "edits"
Post by ¼ dead » Mon Mar 05, 2018 1:13 pm
One quick-and-dirty way of making audio collages that doesn't require tape splicing would be to get a 4-track recorder, and possibly a second tape recorder for bouncing sources from one tape to another. The results aren't nearly as clean or precise as with manual splicing, but it's fun, and it can make for some interesting sounds.
Similar to what fire said, I generally keep my finger on the input volume of my 4-track recorder, which allows for smoother blending between recorded passages, without too much unwanted machine noise.
I generally mix down everything digitally, but the fun thing about mixing down onto whatever you use from a 4-track recording is the ability to pan and fade each individual track and alter the playback speed in real time, and to overdub mixes however many times. Adjusting the playback at random means the mixed down results will be different every time.
It's a fun and lazy way to make cut-ups.
Post by xdugef » Mon Mar 05, 2018 6:49 pm
I'm just riffing on the OP's use of the word emulate.. if you want to emulate it then cut and paste on computer is best way to emulate it.. somebody should make a VR tape editor simulator like drunk surgeon... otherwise you just do it as they have tried and it's tedious and prone to error although the later is possibly being why it is of aesthetic interest.
As far as a compositional tool it's not as WYSIWYG as image collage right? Supposedly back when splicing video tape was a thing and you have to cut on the sync pulse there was a magnetic dye you could use to see why there synch pulse was on the tape otherwise for audio I would scrub the tape back and forth until I found where I wanted to cut, mark it and then cut and if you fuck up there is no undo.
Although you can do fun things like just randomly make splices or cut a bunch of pieces the same length or make loops but as soon as you want to do anything with precision you discover why nobody uses tape for editing any more... recording or mastering yes but literal cutting of tape forget it.
Either embrace that it is complete hell or forget it.
