amp oscillation
vnmb
amp oscillation
Post by vnmb » Wed Feb 28, 2018 11:39 am
So i'm trying to make my feedback a little more dynamic like prurient does in this video:
https://www.youtube.com/watch?v=RAw0-lx1gcU
I can sort of do it with on my monitors with lots of volume and if I use my fuzz pedal in the chain. But my small 3w orange crush amp makes a buzzing sound whenever I try to use my fuzz pedal in it. And I can't seem to get the dynamic feedback sound. What is it that causes this and how can I recreate it?
Re: amp oscillation
Post by MKULTRA » Fri Mar 09, 2018 5:22 am
Re: amp oscillation
Post by xdugef » Fri Mar 09, 2018 2:38 pm
It helps to turn your back to the audience also..
Re: amp oscillation
Post by crochambeau » Sat Mar 10, 2018 6:46 am
In all seriousness though, if you're after dynamic feedback (I didn't listen to the track, so forgive me if I'm going the wrong way chasing an interpretation of words) I would reach for an amplifier that isn't shunting out all its headroom from the get go.
You want gobs of headroom left to work with, which generally translates to a more powerful amplifier. 3 watts can get you there, make no mistake, but this is analingus to surfing a mighty short swell and contrary to knee jerk opinion might demand a more attentive touch.
Re: amp oscillation
Post by s.p.i.n. » Sat Mar 10, 2018 7:36 am
click bait
Re: amp oscillation
Post by xdugef » Sat Mar 10, 2018 8:37 am
I wouldn't even call it "dynamic feedback".. it sounds to me like the typical feedback you'd get with too much gain and the mic too close to the speakers.. it's all just high end squealing.. although since the audio is being captured on a video camera I can't be sure that the low end is missing but I'm not expecting there to be any.
vnmb
Re: amp oscillation
Post by vnmb » Mon Mar 12, 2018 6:29 pm
Nvm i solved my problem, i just turned on the monitor on my audio intertace and turned the volume really high.
