How to mute channels in mixer?
GROSS
Post by GROSS » Fri Feb 16, 2018 1:14 am
I like my Behringer Xenyx QX1002 USB mixer, I love that it's cheap and has USB connection. But it doesn't have mute buttons for channels.
In my noise tracks I want to quickly switch between 3-4 channels Kazumoto Endo/Killer Bug style
What should I do to have both USB connection and mute function?
I'm thinking about these solutions:
1) Sell Behringer and buy Mackie PROFX8V2 (has both USB and mute). But Mackie is too expensive
2) Buy Boss TU-3 Chromatic Tuner. I heard it can block the channel. But you have to buy them for every channel you use
3) Buy Boss NS-2 Noise Suppressor with mute function. But again, expensive "mute pedal" for every channel?
4) Boss LS-2 Line Selector. But you can choose only between two lines
What else can you recommend?
Re: How to mute channels in mixer?
Post by Bipolar Fucking Joe » Fri Feb 16, 2018 6:17 am
The Mackie is a pretty nice mixer, for what it's worth.
It sounds like your biggest issue is funds, so I would recommend making "Kill switches" and putting them right before sound enters the mixer. They're really cheap, just one button / switch and two 1/4" sockets for each channel. Borrow a soldering iron if you don't have one. The most expensive part of it will be the case. If you can't solder, now is a great time to learn.
