Octave/Pitch Shifter
Minnie
Post by Minnie » Thu Oct 12, 2017 3:02 pm
Heyheyy
So Im looking to get a pitch shifter/octave pedal for my setup and I was wondering which one to get?
I know there's the UO300 by Behringer which is prob the cheapest but I read about what people think about Behringer—and yeah, seems like cheap toys that break easily. Im really just looking for something cheap since I have a low budget.
My dream would be to get a PS2/PS3 by Boss since I heard that they're great for feedback loops/mixer setups.
So any suggestions in between the UO300 and the PS2 are much appreciated! :help:
Re: Octave/Pitch Shifter
Post by Misomusist » Thu Oct 12, 2017 3:13 pm
I have the Behringer US600 and it's working fine for me, I'm not super harsh on my pedals tho' I don't crank on the knobs or stamp on them, though I do throw 'em in a bag to carry them.
You might want a cheap rack unit, unless you really need the pedal style, they can be hardier, and can often be found cheap on craigslist, I picked up an ART for $15 and a Quadraverb for $20.
Minnie
Post by Minnie » Thu Oct 12, 2017 5:40 pm
Cool yeah this one looks good. How is the possibilities in terms of shaping the sound?
diurnalburdens
Post by diurnalburdens » Fri Oct 13, 2017 3:17 am
Danelectro Chili Dog has the best octave/2 octave down sound. And they are pretty cheap. However there's a slight volume drop and it tends to cut off some of the high end of the original signal.
Arion Octaver is damn good and pretty cheap.
I remember really enjoying the Boss PS -5 though it doesn't have the same lofi pitch shifting quality as the PS2/PS3. Damn versatile though.
My favourite nowadays is the Dwarfcraft Wizard of Pitch. Pitch shifts like a PS2/PS3 and has a variable speed crossfade between clean signal and pitchshifted. Does +1 and -1 octaves. Plus a random pitch shift function.
Post by Misomusist » Fri Oct 13, 2017 5:31 am
It's got a bunch of modes, in pitch shifter you can raise and lower up to 2 octaves, it's something like +/- 3,5,7,oct,2oct (he says without checking a manual), then there's harmonizer mode, which goes to +/- octave in smaller increments, which I've never really figured, and a trem bar mode where pushing the pedal causes the sound to go from neutral, up or down to the selected level, and a wobbly mode where it'll sort of rubberband around it, it's got a dry out only which turns the other input to a wet out, and it's got a CV control in, for warping it with a pedal. It's probably based off a Boss.
Minnie
Post by Minnie » Fri Oct 13, 2017 7:47 am
Sounds great, so do you think its worth it for the money? Since the build quality seems kinda cheap im afraid it'll break. Maybe Id should get another one from another brand? Or would you say its fine? Cause I know a place where I can get this one and its really tempting im just wondering if its worth the money. Im also not treating my pedals hard/rough so maybe its fine.
-V-
Post by -V- » Fri Oct 13, 2017 2:44 pm
I had the us600 but sold it after a couple of days. Just didn't enjoy using it, I found it sterile and was instantly disappointed.
The pitchshifter on behringer fx600 multi fx pedal was more enjoyable.
Guess it depends on what you want to do with it and how accurate you need it to be.
But forget all that anti behringer snobbery :D
Post by Bipolar Fucking Joe » Sat Oct 14, 2017 4:33 am
I recommend the Digitech Whammy. I never used the DT version, but the 5th gen. version is solid. It's much dearer than the Behringer, but will last you years.
Minnie
Post by Minnie » Sat Oct 14, 2017 5:41 am
Hmm okey interesting! The fx600 is also a possibility. Im just gonna use it for making noise/ambient music. So together with other pedals in feedback loops and for contact mic recordings. So how come you find the fx600 more useful? Im curious about it and wonder how it affects the sound!
-V-
Post by -V- » Sun Oct 15, 2017 4:01 am
I was using the pitch shifter to beef up synths.
With the fx600 I could just adjust the knobs and get satisfying sounds.
The us600 is tied to specific notes ( IIRC - going back a couple of years ) so a less fun approach.
There was also something about the sound / tone I didn't like. Instant nope. Couldn't really put my finger on what it was but it was back on ebay within hours.
I'd definitely recommend the fx600. You'll probably get it cheaper than a us600 and comes with a simple but perfectly acceptable delay.
Minnie
Post by Minnie » Sun Oct 15, 2017 4:21 am
Hmm yea im really not sure which one to get. It seems like a lot of people really like the us600 in feedback loops and says its perfect for a cheap pitch shifter that sometimes even work better than the boss that it's based on. The fx600 seems to have less knobs and since its a multi-fx its a jack of all trades so i cant image it would work better than the us600? I guess when you use it for synth and need to hit specific tones but im more interested in just fucking up the sound. :twisted:
Post by Bipolar Fucking Joe » Sun Oct 15, 2017 5:26 am
More knobs doesn't always make a piece of kit better, but it is more fun to play with.
On a side note, there's no Behringer snobbery, they get a bad rep because their shit breaks real easy. Two Behringer pedals I got came in the post pre-broken, but I know a guy who had the same Behringer mixer for years, and I know Tim Drage likes them because they're cheap.
Honestly, I think the Digitech Whammy will be the only pitch shifter you'll need, and you can do wicked cool divebomb effects. It took me a couple of years to get over the fact that I should just buy something a little dearer than I liked at the time, in order to save money down the road having to buy another piece of kit because the cheap thing broke.
Post by MKULTRA » Sun Oct 15, 2017 6:16 am
Dyecap
Post by Dyecap » Sun Oct 15, 2017 7:13 am
I have the US600 but it gets little use.
Isn't it a PS-5 clone?
It sounds soft/spongy to me :shrug:
Can spit some interesting digital fizz in a floop between dist. though...
PS-2 is ok and does have a sharp feel. Let mine go to someone desperate for it.
PS-3 is king. No doubt at all. Hard. Precise(ish). Stereo. Reverse/pitch/delay (No.7) is fun. Stereo!
Get the behringer and play with it maybe with an eq...?
You can always sell it on if you don't gel.
Dyecap
Post by Dyecap » Sun Oct 15, 2017 7:18 am
Although...
The PS-3 is not through stereo.
Rather independently pitchable outs on a couple of modes only.
