My handmade noise machine!
AlmightyHades
Post by AlmightyHades » Fri Mar 31, 2017 3:11 am
Hey guys, I made this Noise machine for less than ten dollars! It's the cheapest gear you can have I think :-D
Re: My handmade noise machine!
Post by xdugef » Fri Mar 31, 2017 6:24 am
It's not cheaper than free
Post by Sleep Of Ages » Fri Mar 31, 2017 7:38 am
Not cheaper than cans and rocks and sticks and trash.
Post by Misomusist » Fri Mar 31, 2017 8:47 am
Why use an Arduino? You can make a noise with a couple of transistors and some passives.
Post by xdugef » Fri Mar 31, 2017 9:38 am
true and Arduino's usually cost more than $10 brand new so where did you get that deal?
Post by Laura91 » Fri Mar 31, 2017 9:39 am
passives?
Post by xdugef » Fri Mar 31, 2017 9:42 am
passives?
A passive component is a module that does not require energy to operate, except for the available alternating current (AC) circuit that it is connected to. A passive module is not capable of power gain and is not a source of energy. A typical passive component would be a chassis, inductor, resistor, transformer, or capacitor.
Post by MKULTRA » Fri Mar 31, 2017 12:36 pm
AlmightyHades
Post by AlmightyHades » Fri Mar 31, 2017 12:39 pm
Probably the easiest tool I had in my lab stuff. But, I'll try transistors.
Post by Misomusist » Fri Mar 31, 2017 12:51 pm
Pet peeve of an older dude, why is everyone using Arduinos for stuff that can be done with a regular circuit. :mrgreen:
But at least your building stuff, and the Arduino can be used, not just as an oscillator, but to do FX and stuff, so you could expand it.
Post by xdugef » Fri Mar 31, 2017 12:56 pm
I assume if you are learning arduino you gotta start somewhere?
