Help with AU Parametric EQ plugin
Post by FireAlarmPoet » Wed Nov 16, 2016 6:34 pm
So I'm using Apple's AU Parametric EQ plugin on Audacity and when I hit "apply," my changes never happen! The changes will only be heard as long as the plugin's menu is opened, then once it's closed it's like it never happened, but Aduacity will atill allow me to undo or redo the change as if it had been applied successfully. I don't have this problem with the AU Graphic EQ plugin sop what am I doing wrong?
Post by MKULTRA » Thu Nov 17, 2016 2:26 am
Post by fire » Thu Nov 17, 2016 5:09 am
jesus, cant the admins do something about the constant spamming around here???
GO SELL YOUR PLATINUM COATED FRYING PANS ELSEWHERE, SPAM BOT
Post by Misomusist » Thu Nov 17, 2016 6:57 am
You forgot to add GET OFF MY LAWN!!!!! :mrgreen:
Post by MKULTRA » Thu Nov 17, 2016 11:34 am
Post by fire » Thu Nov 17, 2016 12:40 pm
MKULTRA wrote:Plus ca change, plus c'est la meme chose Fappy.
easy for you to say
anyway, fappy, after 6600+ posts dont you know it all already?
Post by xdugef » Mon Feb 20, 2017 6:57 am
MKULTRA wrote:You said Apple.
