Different cassette types in multitrack recorders
Bakon
Post by Bakon » Tue Aug 20, 2013 12:18 pm
Does it really matter what kind of cassettes you shove in a cassette multitracker?
Like, if the manual says to use eq 70 cassettes ONLY, does it really mean ONLY or can I use 120 eq cassettes as well? What's the actual difference?
120 min cassettes I can understand, since the tape is so thin it might break under the stress, and I don't think you can even get metal tapes these days, but most new cassettes I can find online or nearby stores are 120 eq's.
Post by timdrage » Tue Aug 20, 2013 12:37 pm
I've used all sorts of stupid/cheap tapes in them. Long tapes are indeed more likely to snap. Type I tapes won't sound as good as type II. Both/any are fine/great for noise.
Clean and demagnetize your tape heads regularly and use whatever tapes you can get is my advice. :)
I use C90s all the time and only had old/broken players chew them, and use type I with OK results.
I put a Chrome C1 (!!) tape in my 4track once and it snapped immediately upon reaching the end.:D
Hal McGee wrote:In the 1980s most of us used High Bias tapes for the best possible sound quality. In those days if somebody sent a tape release on a Normal Bias tape we assumed that they really didn't care very much about their music. Then, when I made contact with mid-1990s era hometapers like you and Noring, I was surprised that use of Normal Bias tape was commonplace. Once, during a visit to Noring I questioned him about why he would use Normals instead of Highs, and he pointed to the plastic wrapper on a Maxell Normal Bias tape and said, "See, it says here: Great for everyday recording"-which was all the convincing I needed.
http://livingarchive.doncampau.com/inte ... -hal-mcgee
Bakon
Post by Bakon » Tue Aug 20, 2013 1:26 pm
Ok, so it's more of a sound quality thing as I suspected.
And sound quality be fucked.
Post by xdugef » Tue Aug 20, 2013 1:53 pm
Bakon wrote:Ok, so it's more of a sound quality thing as I suspected.
Longer tapes are thinner and more likely to warp stretch or break
Bakon
Post by Bakon » Tue Aug 20, 2013 1:58 pm
Ya, but I don't think that has nothing to do with eq, since you get just as long tapes both with eq 70 and eq 120.
Post by xdugef » Tue Aug 20, 2013 2:34 pm
You asked if it really matters what kind of cassettes you shove in a cassette multitracker... shove whatever tapes you want.. I'm just pointing out the potential hazard of using longer tapes.
Post by timdrage » Tue Aug 20, 2013 2:43 pm
It just has a bit less frequency range. It's fine, probably there's something wron with your 4track if it sounds really bad. Even low grade type 1 tape will sound better in a 4 track (assuming you're recording at high speed) than in a normal tape recorder.
Post by xdugef » Tue Aug 20, 2013 2:49 pm
timdrage wrote:(assuming you're recording at high speed)
even more of a reason to avoid long tapes
Post by MKULTRA » Tue Aug 20, 2013 2:53 pm
Reuse / recycle old tapes.
DIY or DIE!!!!!
Spray paint the phuk out of them.
Less internet - more doing.
Post by Sleep Of Ages » Tue Aug 20, 2013 4:15 pm
MKULTRA wrote:
Less internet
Nonsense
Post by xdugef » Tue Aug 20, 2013 4:40 pm
MKULTRA wrote:Reuse / recycle old tapes.
DIY or DIE!!!!!
just dunk the fucking tapes in house paint and call it a day
Post by Sleep Of Ages » Tue Aug 20, 2013 6:01 pm
Dye or Die
Bakon
Post by Bakon » Tue Aug 20, 2013 8:41 pm
Yes, but given that I also mentioned that I understand why 120 min tapes are a no-no because they might snap, it could be deduced I was aware of the hazards of longer tape.
(sorry, rough night)
Post by xdugef » Wed Aug 21, 2013 5:55 am
yeah long tapes are bad
Post by timdrage » Wed Aug 21, 2013 6:28 am
did anyone mention yet that long tapes are not very reliable? :D
