thegreatbelphegor
Post by thegreatbelphegor » Tue Jul 30, 2013 4:58 am
Last edited by thegreatbelphegor on Fri Jul 29, 2016 10:29 pm, edited 1 time in total.
Refund
Post by Refund » Tue Jul 30, 2013 5:56 am
to come up with ideas to mod a record player, you just need to understand how it works.
this is how the record needle gets stereo
http://www.vinylrecorder.com/stereo.html
the four wires in this picture are for the two pairs (L and R) of audio outputs, they send out unamplified signals (just like a microphone)
http://turntabling.net/wp-content/uploa ... needle.jpg
the signals then go through a 'phono amplifier' which not only amplifies the signal, but also puts it through an equalisation curve
http://en.wikipedia.org/wiki/RIAA_equalization
There are also belt drive and direct drive turntables.
http://en.wikipedia.org/wiki/Direct-drive_turntable
http://en.wikipedia.org/wiki/Belt-drive_turntable
that should be enough information for you to conceptualise your own modifications.
Post by MKULTRA » Tue Jul 30, 2013 6:06 am
78rpm records sound like doom at 16 speed.
Still a go to machine.
Leporidae's DC driven rig.
Militant Electronics
Post by Militant Electronics » Tue Jul 30, 2013 6:22 am
16rpm, sounds awesome. Reminds me of how more evil tapes would sound once the battery was close to empty.
Not really a mod but a nice thing anyway: Svartvit used a locked groove Vomir 7" and fed it through some distortions. The degradation of the medium caused a change in texture.
thegreatbelphegor
Post by thegreatbelphegor » Tue Jul 30, 2013 6:24 am
MK , what does the second one sound like ? Whats with the cable being attached to the arm ? I wanna try that :?:
thegreatbelphegor
Post by thegreatbelphegor » Tue Jul 30, 2013 6:27 am
I want this shirt http://www.nightchannels.com/shop/produ ... trol-p-432
MK you might like that
Post by MKULTRA » Tue Jul 30, 2013 6:28 am
Piezo'd reproducer on a child's 78 player.
Post by MKULTRA » Tue Jul 30, 2013 6:29 am
Variation on a theme.
thegreatbelphegor
Post by thegreatbelphegor » Tue Jul 30, 2013 6:30 am
That should be easy for me . I have a few contact mics laying around . But what does it sound like ?
thegreatbelphegor
Post by thegreatbelphegor » Tue Jul 30, 2013 6:31 am
Oh shit that looks cool as fuck
Post by MKULTRA » Tue Jul 30, 2013 6:35 am
There are all manner of philosophies in heaven and earth.Image
Post by timdrage » Tue Jul 30, 2013 6:36 am
Emil Beaulieau had some modded record players to make harsh noise.
yeah - he modded them by playing other people's harsh noise records on them :D
(seriously tho yep he had some modded ones; they had extra arms, and also a cartridge not on an arm but just on the end of a cable so you can play the record or any object manually...)
thegreatbelphegor
Post by thegreatbelphegor » Tue Jul 30, 2013 6:38 am
You took the needle out and placed a spring ?
Post by timdrage » Tue Jul 30, 2013 6:43 am
another idea would be to make the record player go backwards. depending on how it's driven that may or may not be easy, also it may wreck non-DJ needles i guess.
Or even play it backwards WITHOUT a mod: one DJ/turntablist gimmick is to turn the cartridge upside-down, adjust the counterweight so the arm goes up instead of down, and play the underside of a record on a roll of gaffer tape placed on the turntable :D
Post by jliat » Tue Jul 30, 2013 7:14 am
you could play these - and they are
1) harsh
2) the harshness is objective - Sanding Discs 15pc - 3 Grades
