Amp owned by smoker - wat do?
Post by FireAlarmPoet » Sat Apr 27, 2013 12:23 pm
Okay, so I went grage saling today and fuckin' BANKED.
Among other things I got a tiny Crate amp, about the same size & functionality as my other Crate amp, only newer/nicer.
Only problem is it smells like cigarettes when you get your nose right up to it (and I didn't notice this when I bought it :wall: )
I heard cig smoke is hell on electronics, so should I open it up & air it out? Should I do more than that, or is it fine on it's own?
reply
Post by Laura91 » Sat Apr 27, 2013 12:32 pm
I suppose it couldn't hurt to air it out as long as you don't damage it.
Post by ¼ dead » Sat Apr 27, 2013 12:44 pm
"Only problem is it smells like cigarettes when you get your nose right up to it"
Don't stick your nose on it, genius. This is such a non-problem, is sort of mind-boggling that you're even ask.
I had a tiny crate amp that also smelled (as in, reeked [as in, made my entire room smell like stale cigarette smoke]).
It worked fine until I blew it the fuck up.
My best advice is to quit being a helpless baby and try sitting down and using your own brain to come up with possible solutions. Chances are, even you could come up with something...
Like, IDK... wiping it down for one thing... WHOA! Who'da thunk?!
(now let's get creative)
Like setting (non-burning, duh) incense inside the cavity for a long time...
Like rubbing the inside and outside's non-electronic portions with diluted essential/aromatherapy oil(s). Something that'll mask the smell and also hopefully mask the scent of rotting semen in your room. There's lots and lots of lovely scents to choose from.
Like cleaning the board and back of the speaker as best you can with q-tips and a cloth dampened with some high-concentrate isopropyl alcohol.
Shit wuz really hard. I had to think about it for an entire minute! Pay me. ;_;
Setting it outside in the shade on a dry day (or two) certainly wouldn't hurt either, I don't think. Just don't leave it out in the baking sun, wet cold or humid air.
Re: Amp owned by smoker - wat do?
Post by Laura91 » Sat Apr 27, 2013 1:34 pm
FireAlarmPoet wrote:Okay, so I went grage saling today and fuckin' BANKED.
What other stuff did you get?
Post by FireAlarmPoet » Sat Apr 27, 2013 1:52 pm
Working:
1x tronic turntable (speaker is busted, need to find right attachment to bust it open & fix it)
1x playskool cassette recorder w/ micm (thought it had a vox changer, didn't)
1x phineas & ferb voice changer (^.^)
1x 1/8" cassette splicer (!!!)
1x Hot Hot Heat - Make Up The Breakdown CD (girl wrote "lead singer is hot - they rock!" on the disc, lol)
2x extremely small walkie talkies, one with a strange high-pitched squeal (planning on making some sort of wireless preamp/shitty oscillator with them)
2x big aluminum ice skate boxes (makes lots o' din)
Junked:
1x keyboard (saved the speakers for turntable)
2x telephone baby toys (speakers were both junk; battery packs corroded beyond repair)
and some other shit I can't remember naymore ahahah
Post by xdugef » Sat Apr 27, 2013 1:59 pm
FireAlarmPoet wrote: I heard cig smoke is hell on electronics, so should I open it up & air it out? Should I do more than that, or is it fine on it's own?
It'll be fine.. if it stinks then air it out.. wipe it down.. dust it out.. etc
Post by crochambeau » Sat Apr 27, 2013 2:25 pm
Cigarette odor usually goes away in a few weeks, I wouldn't worry about it.
Only stuff tar will really affect are switches and moving/slip contacts. Actual amp circuitry (we're just talking solid state here) could be dipped in epoxy or rubber and still work just fine, aside from thermal insulation at power sections.
Post by MKULTRA » Sat Apr 27, 2013 3:17 pm
Cancer is still a possibility,
Give us a money shot of yer bounty.
FireAlarmPoet wrote:[1x 1/8" cassette splicer (!!!)
The journey of a thousand miles begins.
Baby steps.
Practice your splicing skills.
Learn how to get seamless edits.
Do a hundred, then do a hundred more.
Don't flake out after ten.
This is a SKILL. It very rarely comes naturally.
You can do serious work with loops.
Learn and develop this SKILL.
Loops of the art.
http://www.soundonsound.com/sos/jun05/a ... tracks.htm
Money is 5th paragraph down in Blunt Instruments.
I've posted this one before and probably is tl;dr for those with a microwave mentality.
Unless you've heard the song nice and loud on vinyl, it really is hard to appreciate fully. YMMV.
Post by Sleep Of Ages » Sat Apr 27, 2013 4:01 pm
8)
I like this thread
Post by FireAlarmPoet » Sat Apr 27, 2013 4:07 pm
¼ dead wrote:Image
fyi it's not the smell itself I care about, it's what the smell means.
I smell a smelly smell, but all I give a shit about is if it fucks up the machine or not.
I can tolerate cig smell if it only has about an inch of range.
Anyways, thansk for all the input: I ended up opening up the back (easiest thing I've ever unscrewed & put back together), set it outside and put my mom's fan on the now open back at the highest setting for ~30 minutes. I put in a little air freshener (the fancy shit, not like febreze) jsut to be safe, but not too much. Didn't really eliminate the smell, but after looking at the nearly flawless [and dustless] guts I'm satisfied enough.
Post by Sleep Of Ages » Sat Apr 27, 2013 4:14 pm
This post is a fine example of how you can:
a) be an asshole and keep NG shitty, because you don't like someone on the internet
b) try to be helpful and advance the thread further
c) be helpful
d) be helpful and explain beyond it
e) even if you are an asshole and probably dislike the poster, you can take the information shown and up the ante, making the thread glorious by talking about tape loops and reaching an analysis of the recording of a 10cc track
Usually we choose the A option... :|
Post by FireAlarmPoet » Sat Apr 27, 2013 4:39 pm
your sig still slows me down, dick.
reply
Post by Laura91 » Sat Apr 27, 2013 5:04 pm
I love my sig. :love:
Post by Sleep Of Ages » Sat Apr 27, 2013 5:32 pm
FireAlarmPoet wrote:your sig still slows me down, dick.
Luv ya 2, dawg
Post by crochambeau » Sat Apr 27, 2013 8:29 pm
Your need of an update is not the problem of another person.
