One Dimension
JoeTheStache
Post by JoeTheStache » Sun Mar 31, 2013 11:06 am
xdugef wrote: Another long time favorite has been scrambling the memory indexes via circuit bending on digital delays. I don't know what you'd call the effect. At times it can sound like a variety of effects.
I would like to hear this and perhaps learn to do it.
Post by amishrobots » Sun Mar 31, 2013 11:13 pm
crochambeau wrote:
jliat wrote:Then amplification has to be the most important-
Yeah, if amplification is considered an effect then all other "effects" are useless. Nearly every single one of them (with the exception of passive tuned circuits)
have amplification as a fundamental building block, even if it's just a gain recovery stage. Hell, I even consider buffers amplifiers.
In my world view, functional blocks which are intended to preserve the original signal intact as possible are not effects. Preamps, mixers, amplifiers, etc are not effects in my opinionated definition.
So, let's say ignoring amplification & mixing as a given..
If it's the application of tools, ie: the resulting artifact that is considered an effect, I'll change my answer to distortion....
Then realize that such a limitation is impossible, because simply placing a speaker in a room is EQ & reverb. Hanging a mic in front of a speaker, then shifting it off axis is EQ. etc, etc, etc.
So I really feel that the only way for me to answer this question honestly rolls back to my original interpretation.
yeah, lets just stick with; "what's your favourite thing to do to an audio signal?"
Al.Machine.O
Post by Al.Machine.O » Mon Apr 01, 2013 2:23 am
amishrobots wrote: yeah, lets just stick with; "what's your favourite thing to do to an audio signal?"
stickin` my thing into my girlfriend - she makes lovely noises :twisted:
Laura91 wrote:To all that use feedback loops:
Flooping causes hiccups.
Post by crochambeau » Mon Apr 01, 2013 7:47 am
amishrobots wrote:"what's your favourite thing to do to an audio signal?"
Depends on my mood, really.
Now I'm just being difficult.
Post by amishrobots » Mon Apr 01, 2013 7:16 pm
So your favourite effect is pleasure. I should look up circuit diagrams for that. Anyone be interested in buying a pedal if I built it?
NoizeHack
Post by NoizeHack » Mon Apr 01, 2013 9:44 pm
Yeah I second this, I am super down for a how to scramble memory indexes in a digital delay tutorial.
ob1117
Post by ob1117 » Tue Apr 02, 2013 1:06 am
I also would like to hear about memory index scrambling.
Al.Machine.O
Post by Al.Machine.O » Wed Apr 03, 2013 2:42 pm
An amplifier....
VOLUME-KNOB. :l33t:
Post by xdugef » Wed Apr 03, 2013 2:50 pm
ob1117 wrote:I also would like to hear about memory index scrambling.
Well you basically locate the memory chip and make connections between the legs that didn't previously exist.. thus creating a short circuit.. it's also sometimes called a shit shot.. this is has more to do with toy keyboards that have ROM and when you short the legs the memory gets scrambled until your reset the power.
Anyway.. the way this works is that several of the legs of the RAM chip give access to indices of memory locations. Different combinations return different values stored in the chip. So there's a sequence that steps through there various combinations to access of the samples of the audio stored in memory. When you short the legs it causes the chip to return the wrong samples or erroneous values which produces sounds from something like a ring modulator to full blown ear sizzling distortion.
Post by ¼ dead » Wed Apr 03, 2013 9:48 pm
Yeah, bro! *high five* 8)
suspiria 23
Post by suspiria 23 » Fri Apr 12, 2013 10:43 am
I like the effects of "delay" the best, although my avatar would suggest differently....
Refund
Post by Refund » Fri Apr 12, 2013 1:44 pm
if you're allowed to use only one 'effect' but as many times as you want, then delay would win the game for me
comb filtering, robot sounds, and other super short delay time effects
feedback loop mangling
stuttering
looping
pitch shifting
creating 'pads' using fade ins and heaps of feedback
Post by MKULTRA » Tue Apr 23, 2013 11:58 am
Post by crochambeau » Tue Apr 23, 2013 12:02 pm
Slew rate limiting and thermal drift are just a facets of distortion.
Post by xdugef » Mon Feb 20, 2017 7:52 am
MKULTRA wrote:A mixer is not an effect. Your argument is invalid.
Echoplex.
