One Dimension
One Dimension
Post by amishrobots » Thu Mar 28, 2013 9:26 pm
If you could only use one effect what would it be?
Not "one pedal", but just one effect, like, fuzz, tremolo, echo, chorus, ring modulator, etc.
Al.Machine.O
Post by Al.Machine.O » Fri Mar 29, 2013 12:34 am
a long delay (rate & time set max, 100% wet) <- tap delay setting on behri em600
Laura91 wrote:To all that use feedback loops:
Flooping causes hiccups.
NoizeHack
Post by NoizeHack » Fri Mar 29, 2013 2:13 am
distortion
Post by amishrobots » Fri Mar 29, 2013 2:35 am
i'm thinking some sort of comp or collab should come of this
Post by xdugef » Fri Mar 29, 2013 5:07 am
but what if all your sounds sources are from other effects?
Post by Sleep Of Ages » Fri Mar 29, 2013 7:12 am
Noise Limiter
Al.Machine.O
Post by Al.Machine.O » Fri Mar 29, 2013 7:23 am
killswitch o_O
Post by crochambeau » Fri Mar 29, 2013 9:30 am
Compression.
Post by xdugef » Fri Mar 29, 2013 10:11 am
mixer
Post by timdrage » Fri Mar 29, 2013 1:13 pm
Seconding 'Mixer', that's the correct answer
Post by Sleep Of Ages » Fri Mar 29, 2013 1:14 pm
Dizzyness.
RJMyato
Post by RJMyato » Fri Mar 29, 2013 1:24 pm
Al.Machine.O wrote:killswitch o_O
Halo of Teeth
Post by Halo of Teeth » Fri Mar 29, 2013 3:35 pm
if i was restrained to the use of just one kind of pedal i'd go with nothing but various loopers, ideally loopers with over a minute of loop time.
RJMyato
Post by RJMyato » Fri Mar 29, 2013 3:38 pm
One Direction
Post by Sleep Of Ages » Fri Mar 29, 2013 3:43 pm
One love
